I recently created an add-in that adds error handling to the function/sub
your cursor is in.
Create a new project and select "Addin" for the type of project. This will
create an addin for vb. You can't create an addin that will work both in vb
and vba since both ide's have similar object models with objects having the
same name. In the project browser, dc on the designer for connecting to the
ide. Change its Application property from VB to vba ide. Go to
Project>References and make sure that the reference to the vb ide is
unchecked and that "Microsoft Visual Basic for Applications Extensibilty
5.3" is checked. That should be all you need to do.
Ed
"Anthony" wrote in message
news:40ec4510_1@newsprd01...
> I have VB 6 installed on my comp and I found a simple add-in example, but
it
> doesnt seem to work in AutoCad's Add-in manager (however it works fine in
> the VB6 add-in manager).
> -A
> "Ed Jobe" wrote in message
> news:40ec3d84_1@newsprd01...
> > If you have vb6. Not with vba, though.
> > Ed
> > news:40ec35e3$1_3@newsprd01...
> > > I would like to write an add-in to simplify my very repetitive code
> > writing
> > > in AutoCAD vba, but i cant figure out how? Is it possible? I'd love to
> be
> > > able to get it to write a few hundrend lines of code for me per
> project...
> > > -A
