VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
AUTOVBALOAD.LSP by Tony Tanzillo
7 REPLIES 7
Message 1 of 8
259 Views, 7 Replies
Hi All (& Tony if you're around)
in the following Tony said "executes a macro
defined in the DVB file."
But for the life of me I can't get the routine to run.
http://www.caddzone.com/autovbaload.lsp
I've tried it out from a toolbar with:
(AutoVBALoad "fxBreakLine" "fxBreakLine.dvb" nil)
The command is created - if I type fxBreakLine at the command line it does execute.
Any ideas how can I get it to work when AutoVBALoad is executed?
Cheers in advance.
Dave F.
7 REPLIES 7
Message 2 of 8
Just realized I've posted it in (kind of ) the wrong NG.
However, if anybody here knows...?
Ta
Dave F.
Message 3 of 8
Not sure why you're putting that in a toolbar.
The toolbar button macro should only execute
the command, not call the LISP that defines the
command.
Put the code in a file that's loaded at startup
(like your .MNL file) and make sure your DVB
has a macro called 'ThisDrawing.fxBreakLine'.
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Dave F." wrote in message news:5784157@discussion.autodesk.com...
Cheers in advance.
Dave F.
Message 4 of 8
> command.
Hi Tony
There appears to be some confusion.
The routine is in my acaddoc.lsp.
The ToolBar Icon was calling this:
I was under the impression that this would run the macro called fxlinebreak.
However it seems I need to call it like this:
(AutoVBALoad "fxBreakLine" "fxBreakLine.dvb" nil);fxBreakLine
Is this correct?
Not sure what the significance of ThisDrawing is. I only use that within my macro.
What is it for?
Thanks for your help.
Cheers
Dave F.
Message 5 of 8
Be sure to have a file called ACAD.RX in your search path.
That (text) file must have the line :
ACVBA.ARX
this will tell autocad to load the VBA environment.
In vba editor with NEW , create
ACAD.DVB
go to the Visual Basic Editor
under THIS DRAWING you will see the file ACAD.dvb
put there the lines:
Sub ACADStartup()
Call AcadApplication.LoadDVB("fxBreakLine.dvb")
End Sub
At the toolbar use the command:
(command "vbarun" "fxBreakLine")
That will run your macro.
Every time autocad starts up it will load the program(s) mentioned under Sub
ACADStartup().
You only need to call the right macro.
This is how I do all my VBA macro's.
Lol.
execute.
Cheers in advance.
Dave F.
Message 6 of 8
Perhaps you should try to understand what the purpose
of 'autoloading' is. The purpose is to eliminate the need
to load a DVB file at startup, and only load it if/when you
actually need it.
AutoVBALoad is one way to achieve that, because it lets
you have many DVB files that are only loaded if they're
needed, but are never loaded otherwise.
"The Marker" wrote in message news:5784834@discussion.autodesk.com...
ACVBA.ARX
ACAD.DVB
Sub ACADStartup()
End Sub
ACADStartup().
Lol.
execute.
Cheers in advance.
Dave F.
Message 7 of 8
I only make VBA macro's that I need very often, so wat's the point.
If I would use them ones a month, its not worth to make them .
And that few kb in memory is not the problem, there is enough available.
"Tony Tanzillo" wrote in message
news:5785012@discussion.autodesk.com...
actually need it.
ACVBA.ARX
ACAD.DVB
Sub ACADStartup()
End Sub
ACADStartup().
Lol.
execute.
Cheers in advance.
Dave F.
Message 8 of 8
If you're a casual VBA user with only one or
two DVB files that don't take long to load at
startup, then what you do for yourself is fine,
but that isn't necessarily the best course for
others.
"The Marker" wrote in message news:5785361@discussion.autodesk.com...
actually need it.
ACVBA.ARX
ACAD.DVB
Sub ACADStartup()
End Sub
ACADStartup().
Lol.
execute.
Cheers in advance.
Dave F.
”Boost
