In autocad 2015 whenever I use VBA application inserting different blocks with attributes autocad works fine for 2, 3 o 4 insertions of blocks. After that when I insert block AutoCAD crashes with error message:
internal error: !dbinsert.cpp@1294: elockviolation
In previous versions (ACAD2014 or earlier) there were no problem with this VBA application.
Any help will be appreciated.
Alex
can you reproduce that with an emtpy drawing and just the lines for inserting one specific block?
If so it will be very helpful to upload that sample-code, the drawing you use here as empty drawing + the block you try to insert.
If it's part from a complete application and it is not reproducable with a sample it will also be difficult for us here to reproduce what you get.
Very important to know also:
- alfred -
The error indicates that you attempted to access the database without first requesting and obtaining permission. Start by making sure you lock the database before attempting to access it. If the lock fails, then something (perhaps an unfinished command) still holds the lock, and your code must either cancel or complete the operation or wait until the database becomes available.
Hi Owen,
How do you lock a database with VBA?
- alfred -
@Alfred.NESWADBA wrote:>> Start by making sure you lock the database
Erm, you can't. I was thinking VB.NET. That makes it a little bit harder to track down the culprit in this case, nevertheless the task remains the same.
I had the same problem - same error, did you manage to figure out what's going on?
Thanks Ed
At the office we recently updated to Autocad 2015.
When I execute my code (insert line of block, change line or block,...), I to get the elockviolation Error.
How can I solve this for VBA?
may I repeat my lines:
Can you reproduce that with an emtpy drawing and just the lines for inserting one specific block?
Otherwise it looks hard to get that isolated as long as nobody else can reproduce that.
- alfred -
The Error was produced with VBA code for block insertion (procedure INSMS1old)
Select client from combobox (form at the bottom of message); name of client gets into name of block and Template.dwg from corresponding folder added to drawing.
Sub INSMS1old(B)
Dim blockRefObj As AcadBlockReference
Dim insertionPnt(0 To 2) As Double
insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
If ThisDrawing.ActiveSpace = acModelSpace Then
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, _
DRIV & NYAC & "Clients\" & B & "\Template.dwg", 1#, 1#, 1#, 0)
Else:
Set blockRefObj = ThisDrawing.PaperSpace.InsertBlock(insertionPnt, _
End If
End Sub
THE PROBLEM WAS RESOLVED WITH PRIMITIVE SENDCOMMAND...-INSERT
Sub INSMS1(B)
Dim blona
blona = DRIV & NYAC & "Clients\" & B & "\Template.dwg"
ThisDrawing.SendCommand ("-insert " & blona & vbCr & "0,0 1 1 0 ")
End Sub
Alex Borodulin
I have tested it with an empty drawing. The result is the same. Most of the times i am able to insert the block once, but then i get the lock violation. Using the sendcommand is not realy an option for me because i need to acces the block to be able to update it. Below is a small part of my code. My program is used to interpret CPT-data. First I select a Zero-point (Nulpunt), then i insert a block with an atribute displaying the level. Then I use Plus (or Min) to position the block on the right position (layer separation for CPT). The block is just a line with a text above (the atribute).
Public NULX As Double Public NULY As Double Public SPLITSLIJN As AcadBlockReference Public DW1 As AcadDocument Dim NULOK As Boolean Public LAAGOK As Boolean Public EINDE As Boolean Public Const LOCATIE_GRONDONDERZOEK = "M:\" Public Const PI = 3.14159265358979 #If VBA7 Then Public Declare PtrSafe Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer #Else Public Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As Integer #End If Sub PLUS() Dim PUNT As Variant PUNT = SPLITSLIJN.InsertionPoint Dim Attrib As Variant Dim DeltaY As Double Dim DY As Double DeltaY = 0.05 PUNT(1) = PUNT(1) + DeltaY DY = PUNT(1) - NULY On Error Resume Next 'already lock violation here SPLITSLIJN.InsertionPoint = PUNT Debug.Print Err.Number On Error GoTo 0 Dim PEIL As String PEIL = Format(DY, "standard") If DY >= 0 Then PEIL = "+" & PEIL Attrib = SPLITSLIJN.GetAttributes Attrib(0).TextString = PEIL SPLITSLIJN.UPDATE SPLITSLIJN.InsertionPoint = PUNT End Sub Sub NULPUNT() Set DW1 = Application.ActiveDocument Dim PPUNT As Variant On Error Resume Next PPUNT = DW1.Utility.GetPoint(, "SELECTEER NULPUNT") If GetAsyncKeyState(vbKeyEscape) Then GoTo EINDE On Error GoTo 0 NULX = PPUNT(0) NULY = PPUNT(1) NULOK = True EINDE: End Sub Sub INVOEGLAAG() Debug.Print GetAsyncKeyState(vbKeyEscape) If NULOK = False Then Call NULPUNT Set DW1 = Application.ActiveDocument Dim Attrib As Variant Dim INVOEGPUNT As Variant On Error Resume Next INVOEGPUNT = ThisDrawing.Utility.GetPoint(, "Geef positie laag") If GetAsyncKeyState(vbKeyEscape) Then GoTo EINDE On Error GoTo 0 Set SPLITSLIJN = ThisDrawing.ModelSpace.InsertBlock(INVOEGPUNT, LOCATIE_GRONDONDERZOEK & "ACADBLOCKS\Laagopbouw.dwg", 1#, 1#, 1#, 0) LAAGOK = True DY = (INVOEGPUNT(1) - NULY) Dim PEIL As String PEIL = Format(DY, "standard") Attrib = SPLITSLIJN.GetAttributes Attrib(0).TextString = DY SPLITSLIJN.UPDATE EINDE: End Sub
Just to make sure: you get the elock-violation at that following code line (and not during the insert)?
I'm not sure about the GetAsyncKeyState ... have you ever tried to just get the point and then test for Err.Number <> 0?
I know that this is not exactly the same, but like you use it this should be just a bit different, because that code also handles none-input too:
On Error Resume Next Pnt = ThisDrawing.Utility.GetPoint( , "Point. ") If Err.Number = 0 then ... do your steps, point is given else ... break, no valid point shown end if
- alfred -
Hi Alfred,
I get a Lock violation when i want to "move" the block. This is bypassed by the "on error resume next"-statement.
The real lock violation happens on the insert of the block. The whole program crashes and I get the following message:
The GetAsyncKeyState is used to exit the code when i press Escape. This code poses no problem.
As it's name contains "Async" I'm not sure if that is thread-safe, that's why I suggested to try my way (which also handles the ESC key + additionally the no-input/just enter).
- alfred -
Hi Alfred,
I tried it your way. It handles the escape key as expected. From now on i will use this method, thanks.
However it does not change anything about the lockviolation...
Do you have verified your code with other drawings and other blocks?
When you installed AutoCAD 2015, have your also installed the service packs for that?
- alfred -
