We are testing our 2008 VBA customization in AutoCAD 2011. We are also testing in in two environments, XP 32 bit and Window 7 64. The XP environment has both AutoCAD 2008 and 2011 loaded.
Everything works fine in AutoCAD 2011 in the XP 2008/2011 environment.
In the Windows 7 64 buit environment, with only AutoCAD 2011 loaded, some modules aren't working.
From what I can gather this has to do with the difference in the references loaded between the two environments.
In the Windows 7 environment, I tried getting rid of the AutoCAD 2011 Type Library and replaced it with the 2008 Library. Again, most functions still worked but some not.
I next tried referencing the file that is named as autocad/objectdbx common 17.0 Type Library (axdb17enu.tlb) in the XP load but when is does load, it gets another name, AXDBlib.
I am NOT a VB programmer. This code was written for us by an outside source who now works for Autodesk. I may have to ask him for help but I thought I'd try here first.
I've attached images of the two Reference list windows.
I'll add that Debugging upon the error goes to this: frmAssignSeal.Show vbModal
I believe I finally solved this by adding axdb17enu.tlb to the Common Files\Autodesk Shared folder.
