I have tested the new Vault Mirror 2014 version and have found that it works as nicely as prior versions. However, the FullMirror option seems to work differently than in prior versions and I wanted to get some feedback as to whether others have found the same behaviour.
In prior versions when I ran VaultMirror with the FullMirror option it first deleted the entire destination folder and then recreated all the files and folders. When I run the FullMirror now it seems to be checking for the current content being up to date and not altering anything that is up to date, it just updates what is new or deletes what has been deleted, much like the PartialMirror option used to do. Or course, PartialMirror doesn't delete content. It still takes longer to Run a FullMirror than a PartialMirror but if there is no updated content it only take a few minutes whereas a FullMirror always took about 1.5 Hrs before.
Is this new behaviour by design or is my Vault Mirror 2014 install not working properly?
Dave
Hey Dave,
I can confirm I am seeing the same here regards new Vault Mirror behavior and have been advised this is working as designed - looking back I cannot see anywhere this behavior was communicated as having been changed though we have of course introduced a number of performance improvements with this app.
At the moment I do not have a 2012 environment to compare with, but suggest as this appears to be the correct behavior and is functioning correctly you should not have anything to be concerned about.
Hope this helps,
