Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Mirror 14 in command line
5 REPLIES 5
Nata_ly
688 Views, 5 Replies
Hi!
I'm a new to using command line, so could you help me please?
I need to start Partial Mirror from command line, so I tape:
C:\Users\****>cd "C:\ProgramData\Autodesk\ApplicationPlugins\Autodesk Vault Mirror 2014.bundle\Contents\V2014\" (to change directory)
C:\ProgramData\Autodesk\ApplicationPlugins\Autodesk Vault Mirror 2014.bundle\Contents\V2014>VaultMirror -PartialMirror -U test -P test -S s-vserver22 -V AOTCVault -L "D:\5\VaultMirror.log" -WR "D:\5" -noFail
But nothing is going on! No error message or smth else. Vault Mirror doesn't appears in processes.
I can call Vault Mirror window without problem, but there are only empty fields:
But I need to make .bat file for Windows task, so I need have all command options in it.
Thank you!
5 REPLIES 5
Nata_ly
in reply to: Nata_ly
-WF "D:\5" -noFail  , of course
olearya
Hi Nata_ly,
The issue here may be the use of -WF.  This switch sets the Vault mirror to use your workspace for downloading, so you don't require a path.  If you want to set the folder location you need to use the -F switch.
The readme could be clearer on this - I am going to look at some better examples.
Allan
Product Manager
Autodesk, Inc.
Nata_ly
in reply to: olearya
Thank you for reply!
But it's strange, because in help for this software I can see:
Can be run from UI or command line Usage:  VaultMirror [-PartialMirror | -FullMirror] [-U user] [-P pass] [-S server] [-V vault] [-L logfile] [-WF Working Folder] [-noFail Move to next file on fail]
Nata_ly
But... it works!
So it's readme file issue.
Thank you very much!
olearya
No problems - we added -WF in 2014 and I think we got a little over excited and removed the "-F" switch from the documentation 🙂
Allan
Product Manager
Autodesk, Inc.
