Where can I find the "VaultMirror-BaseVault.exe" for Vault 2013?
From C:\Program Files\Autodesk\ADMS 2013\SDK, I ran the setup.exe. I then went to the folder C:\Program Files (x86)\Autodesk\Autodesk Vault 2013 SDK\util but there is no Vaultmirror found there.
There is a VaultMirror folder in C:\Program Files (x86)\Autodesk\Autodesk Vault 2013 SDK\VS10\CSharp, but there is no VaultMirror-Basic.exe there.
Kirk
Hey Kirk,
Details here:
http://justonesandzeros.typepad.com/blog/2012/03/wheres-vault-mirror.html
Downloaded and installed the Vault mirror from the app store. During the install, it never asked for the installation directory and I still cant find the VaultMirror.exe that I need to run with the command prompt.
Can you tell me where this was installed to or where I can find the Vault Mirror exectuable?
Allan,
I just looked at my vault mirror log and it does not show any errors. I actually thought that it would be since I just installed ADMS 2013 (was 2012). It seems that the VaultMirror-Basic.exe that I am using is also compatible with Vault 2013.
Can you verify that is the case?
Kirk
Yeah, that should work fine.
The path is used so that the appstore manager is aware of the install, making it easier to install/uninstall and update your app if updates become available. Long path name is a pain but should not affect the cmd line behavior.
Allan,
Thanks for that. I edited my last post. Guess I was doing that while you were typing out your reply....Sorry about that.
Kirk
