If there any easy way to use Drawing Compare on old versions of Vaulted IDWs that doesn't have DWFs (only latest versions does have DWF)?
Hi Maxim,
From the preview pane you need to select the previous revision and select "update view" - if you are looking to compare a dwf which is not associated with a revision and you would still like to do a comparison, you can download the previous version and generate a dwf from the CAD application which could be used in ADR to do a comparison.
Hi Maxim,
As I mention in my post - if you are not using versions and you want to do a drawing compare this can be achieved by downloading the previous version files, create dwf and compare using ADR capabilities.
