Vault Splash Screen - Allow it to be hidden when you click somewhere else
When starting Vault Explorer (all flavours) 2013/2014/2015. the loading splash screen stays on top of everything while Vault loads. There is no way to hide it. This means you can't look at or do anything else in windows while you wait for the application to load. Where it is particularly frustrating, is when an error message pops up on loading and ends up hidden behind the splash screen. The only way you can continue, is to click on the message box in the task bar, and then use "Alt+Spacebar+M" and the arrow keys or mouse, to move the error dialog out from behind the splash screen.
I believe this is a regression. I'm sure that this behaviour was not present in earlier releases, but I could be wrong. More importantly, it is inconsistent with every other Autodesk product I have used. Usually, while the application is loading, you can click somewhere other than the splash screen, and it will hide it behind the active window.
7 Comments
scottmoyse
I think it was like it from 2012 onwards.
mthomas
I agree with Gavin, this is extremely frustrating. I like the splash screen in that I know Vault is starting but don't like that it stays on the top
Mike
ihayesjr
Thank you for posting this idea. We will look into what we can do for it.
karthur1
Wow... I think that is a record for the fastest "accepted" solution... Less 24 hrs.  Way to go Irvin!!
Kirk
ihayesjr
gavbath
Great news to see this one has been implemented! Thank you.
I know it was a minor detail, but it provided so much frustration over the last few years, in small 8 second chunks.
About to test the update now.
gavbath
Just tested it, and it works! The splash screen now disappears when you click somewhere else on the screen. Fantastic.
But... the build number in "Help" --> "About" still says 19.0.49.0 when the Hotfix is 19.0.49.20
