Show only
Search instead for
Vault Plot to include any printable attached files
I attached an IDW file to another IDW file expecting that when I plotted (Vault Plot) the parent IDW it would also plot the attachment. It didn't. I think it should. When I do a Get/Checkout on the parent it also gets the attachment.
Not sure if this would work for your case or not, it works for us.
You can create a view of the common model file (.iam or .ipt) into the Sheet. We often insert the base model into the sheet, but outside the border so you can't see that view when printing, but it allows them all to be linked through the common model rather than thru the manual link you mention above.
So, when plotting, it finds all related files based on the models that were used to create the view. It sees all the .idw's that has the common model in them as a view and plot's them as a set.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Vault product team
