In Vault objects have a property called path. I like to use the property in a rule when determin which category the part is.
For example:
If path contains "LIBRARY" category_name = "Library parts"
If path contains "DESIGN" category_name = "Design parts"
If path contains "Content Center Files" category_name = "CC parts"
In this way a user only has to place the part at teh right location on disk. During initial check in it will get the correct category automaticly.
Any news regarding this? It's really a major issue (in my opinion) regarding assigning a specific lifecycle for Content Center Files.
Actually the solution bellow is not a good one regarding custom parts from Content Center and Frame parts.
https://www.youtube.com/playlist?list=PL9A6632DDBF5C9661
Thanks in advance
This functionality needs to be added to vault. Anyone who has ever tried to implement vault across multiple divisions in a company can speak to how important this functionality would be.
Vault allows us to display the "Path" as column in the UI, so why no love to use it within a categorization rule?
While using templates with a custom iProperty and/or Data Standard help, there are many situations where it does not - categorization by path would be the cleanest solution.
P.S. Depending on the customer and their folder structure, this may also help another issue I have with deploying vault across multiple divisions which is the ability to distinguish the "type" of DWG file.
-Ryan
Ryan Small
SolidCAD (Autodesk Reseller)
The Vault Data Standard feature can be used to accomplish this.
Have you checked to see if this is in the Ideas forum yet? Are you a beta member?
NEVER MIND!
Read back to the beginning. I get it now.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
The request wasn't really solved.
Using the data standard isn't a nice way to work with vault, I think personally.
Beside the creation and management of the scripts to all clients, updating to a new release of Vault can generate extra work as well. If they don't work fine, you have to solve it yourself. Hints and how-to are given by multiple sources but you have to solve it yourself.
It should be a feature inside Vault, not in an add in.
