SystemOption / UserOption
Storing data in system options is restricted to administrators. Why? Propably something like user options writeable for all users would be a solution.
We are developing vault explorer extensions and we often have to store data which must be available / writeable for all users.
--Stephan
4 Comments
ihayesjr
Status changed to: Accepted
Hi Stephen, Can you give some examples of user options that might be set by any or all users? Also, do these options apply to the individual user or applied to all users when they are changed or set?
wannensn
We have implemented a licensing mechanism using system options. At the moment we use it only for the trial period (individual user / all user). But we also think of implementing a per seat licensing mechanism (all users).
I think if there is a central component (vault server), licensing should also a centralized mechanism Combining this with the app store mechanism (download, install/copy, run) I can't think of anything better then using system options.
--Stephan
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
