Revit - Load Family default path
Description
In Revit, on the Vault tab the Load Family button is painfully tedious when locating families to load.
Impact
Having to traverse through the folder structure in Vault until you get to the Revit Families folder every single time you need to load a family is a pain in the butt.
Severity
Medium-High
Solution
Revit requires a pathed setting in the Options on the Vault tab to set a default folder for the Load Family button.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
