Revit - Can't 'Load as Group'
Description
Groups which have been saved out of Revit and placed into Vault, can not then be Loaded as a Group into a future Revit project. There is no integration supporting this architectural workflow.
Impact
Currently a workaround is required to download the group file out of Vault first and then use the regular 'Load as Group'. This slows down an otherwise fast process which Revit users have been enjoying for years.
Severity
High
Solution
We need better integration of Revit into Vault. This is yet another example of why Vault for AEC is not ready for the AEC market. There are plenty of small holes in the integration which need to be addressed first.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
