If you've attempted to use the Refrence Repair Utility you'll quickly become frustrated it could really use some enhancements
Scanning
- In the settings I should be able to browse and select the Inventor Project File. The slash is opposite "/" to all other pathing in the settings and caused me some grief the first time I used this
- I shouldn't have to close the utility when its done processing a folder. I should be able to pick a new folder and continue
- I should be able to select multiple folders to process
- It would be nice to be able to browse for folders to process
- It can error and stop. As a script / batch processing utility it should just log the error and continue. There should be 0-interaction by the user until it is done
- When it errors, it says to look at the log, but when you look at the log there is absolutely nothing about the error or what caused it to stop
Importing Fixes
- I would assume that most people run the scan not on the server, apply the changes to the .xml not on the server, but then need to go to the server to import the fixes. It would be nice to be able to "push" the fixes from the same system used to scan and fix.
- I use the command line to import the fixes but then need to use the ADMS Console logs to see any errors.... huh? The import needs to have its own GUI that writes its own log / error report
