Project links goes to Hard links on check-out in NTFS system
Please, consider possibility to check out Project links as a Hard links (for NTFS).
5 Comments
ihayesjr
Status changed to: Accepted
MiWaNiZa, Can you give a little more information on what you are looking for? Are you trying to force a working folder?
MiWaNiZa
That's right.
While I'm creating link A' (in F' folder) to file A (situated in the А folder) and checking it out (from the Inventor, for example), the file in my workplace appears in folder where A file is located, instead A' location.
It would be logical to download A file and A' link to it. And then link them using hard links. Example diagram is shown below.
john.stewart
This feature would also support  and allow Buzzsaw Sync to place the published linked File in a equivalent Dashboard folder in Buzzsaw.
A good example is Transmittal Files that would be shared with specific Suppliers/Contractors and Customers. Current Buzzsaw Sync requires the Buzzsaw Admin to provide access to Suppliers/Contractors and Customers at the DWG folder level instead of the Linked File Folder location
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
Senthil_Kumar
Status changed to: Archived
