It would be nice if we could perform a Vault Revise command while inside of a Change Order. We're able to do such commands as Change State and Change Catagory inside the Change Order but not Revise? It makes it a pain as a Change Administrator when I notice a Change Order coming through where a file needs to have the revisions matched in Vault to the revision of the Inventor iproperty or AutoCAd border revision. Currently you have to right click on the offending file and then select "Go to folder" to quickly go to that file and then perform a Revise command. It would save a ton of time if we could do this command inside of the Change Order just like most other commands.
