Show only
Search instead for
The current functionality of the Pack and Go is inadequate for Autocad files.
It is not covering ctb files,pc3 files,fonts file...It looks at dwg files like they are from Inventor.
I also don't understand the explanation "If you select these files..." They are not in the Vault, they never where, where does it say they should be?
A new command is to be made, called Vault_eTransmit, while you put it to work DWG True view is working in the background in conjunction with the Vault and then once all the files are in there you can call it "Pack and Go"
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over 2 years and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know - Vault Product Team.
