Can you add the possibility to choose how Vault Explorer will open file, when double-click? Because actually, when double-click an assembly file (IAM) in Vault Explorer (Workgroup or +), it will always open this files with option release-biased. But many people want to double-click on this assembly an open the none-release-biased assembly. Actually, the only method is to use the Open-from-Vault command in Inventor Vault-addin. Thanks in advance.
