Show only
Search instead for
Wes, if you have Inventor installed prior to install the Vault client, the Inventor add-in is installed automatically. It will be listed in the Vault client's customization options. If you install Inventor after you install the Vault client, you can go to the Add/Remove programs, select the Vault client and hit the Change button, then select Add or Remove Features and add the Inventor add-in.
