Edit Properties Flexibility.
I would like to have the ability to set up a pre selected list of properties to edit for a specific object type in Vault Pro.  For example, if I select a File and choose Edit Properties, the edit window would open with a specific list of editable properties. If I select, however, a Custom Object and choose Edit Properties the edit window would open with a different list of editable properties for that object type.  Right now, the only way to do this is with the properties grid.  I have to search through a massive list of system and user properties, highlight the ones I want and choose Edit Selected Properties.  I have to do this for each individual object that I want to edit.
6 Comments
john.laidler
You can edit mulitple properties on mulitple documents in one step.  Select all of the documents, then pre-select the properties.....  then select 'Edit Selected Properties'.
Redmond.D
There are some apps that you should take a look at.
DECO lets you create your own edit window for Custom Object properties.
http://justonesandzeros.typepad.com/blog/2012/07/deco-custom-ui-without-custom-code.html
Reitec.Vault.Datasheet lets you create your own edit window for file properties.
http://apps.exchange.autodesk.com/VLTC/Detail/Index?id=appstore.exchange.autodesk.com%3areitecvaultd...
tmoney2007
This should be default functionality.  Along with multi-select lists for properties and linked lists between fields.
Basically, let someone create a property entry form.
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
