Digital Signatures Directly in Vault
There should be a way to create digital signatures from within Vault that would write directly to the drawing files. Currently if I want a "legal" signature I need to print a hard copy to sign which then becomes the legal copy on file (not the DWG) or I need to publish a PDF and use Verisign which then means the PDF becaomes the legal copy.
It makes sense to me to have all this done directly from Vault (ideally PLM 360 as well).
This is a very important point for regulated industries i.e. FAA, FDA etc.
53 Comments
ihayesjr
Status changed to: Accepted
Hi obourne, is the DWG made from Inventor or AutoCAD?
obourne
IV.
DannyvanDuijn2
A verificated Sign-off method would be very appreciated. When a file/item gets released by an user then the system must verify the user again by showing an extra sign off dialog where the user has to fill in its user credentials.
The workflow would be:
Login Vault > use credentials
Releasing a file / item > use credentials again.
Then the job processor generates the visualization file automatically (in pdf format).
Of course should this be a option which is controlled by the admin.
Danny van Duijn
jeamy.baena
Very important feature!
hugo.trepanier
Many customer need a tool to release their document conditional to a pdf with digital signature. In Quebec Canada the Engineer system need to use Notarius system that digitally sign a pdf document http://www.notarius.com/professionals/oiq.dot#overview. After, inside the vault they need to release their dwg or idw document but with a link with their PDF signed document. My problem consist to configure a condition that force the user to have a correct pdf document link with their dwg/idw document. If the user change state from release to work in progress, the linked pdf file could pass in work in progress state too. After I could simply use the action that the linked file need to be release, but How I could do that?  It could be possible if I could have acess inside the action that the link file need to change on the work in progress state automatically and allow to release a new one.
All source of the problem is about dwf instead pdf, too many pepole use the pdf by default like http://www.notarius.com/professionals/oiq.dot#overview all engineer need to approve PDF, not PDF!  I think that Vault could be a better tool if PDF could be enable instead dwf
Tags (2)
tahdesign1
This is what I was asking for in the following Discussion topic:
http://forums.autodesk.com/t5/Vault-General/Vault-Professional-2014-and-Digital-Signatures-for-relea...
This is something that I think everybody needs and should be built into the release work flow.
agaalen
I agree, very important feature!
ihayesjr
bbuck
Following up on this. Has anything come from this? What other methods are companies using to have users "sign" the inventor drawing files within Vault client? It would be nice if this was integrated with the Change Order workspace so that when a user submits to the "Check", "Review" or "Approved" state, the system would populate the revision table field with the logged in user.
cwindleyZYKGU
Community Visitor
This is brick wall to my company using vault for ECN process. If we are unable to signoff drawing electronically while it is moving through check/review process then we essentially  back to hard copy drawing being passed desk to desk. thanks.
tschaeferZNBXX
This is needed.
Telson.Hadden
This is critical and overdue.  I'm glad it's accepted, can we get some feedback about which version it might appear?
ihayesjr
Telson.Hadden
what? accepted back to future consideration?
WHY please.
drew8QP4W
In the pursuit of going paperless, this would be a game changer.
Cormac_Lyons
If you are looking for an "Electronic Sign off" within Autodesk Vault, then we should be able to assist. In the event of an ECO requiring a "2nd" signature setting (21CFR Part11), then we have achieved this and made Autodesk Vault Professional a solution for regulated industries. The solution meets the FDA requirements and we have worked with some of the worlds largest pharma and med device companies.
Get in touch via www.Procad.ie if you'd like to discuss
Telson.Hadden
This idea needs votes - please send it to all your co-workers, friends, family, strangers and your whole email contact list.
cschnellT2E5T
With the implementation of PDFs, this should be a fairly easy thing to do during the job processing creation of PDFs.  You identify the Approval field, you find the person who did the approval in Vault and add their "signature" to the PDF.
Ideally, it'd be on the original drawing too, but some kind of identifier that the drawing was checked if it's printed is necessary.
Please make this a priority.
dusan.naus.trz
Hi, are you kidding? Isn't it done yet? Ideas from 2012. When will it be?
evenmartinsen
Autodesk Vault should be able to make the signatures on drawings according to rules for electronic signatures, e.g. demand user/password before changing a state. Using Vault in FDA businesses demands the use of third party programs in order to make this.
