5 Kudos
obourne
Digital Signatures Directly in Vault
Status: Comments Requested
by Distinguished Contributor obourne on ‎08-20-2012 10:52 AM
There should be a way to create digital signatures from within Vault that would write directly to the drawing files. Currently if I want a "legal" signature I need to print a hard copy to sign which then becomes the legal copy on file (not the DWG) or I need to publish a PDF and use Verisign which then means the PDF becaomes the legal copy.
It makes sense to me to have all this done directly from Vault (ideally PLM 360 as well).
This is a very important point for regulated industries i.e. FAA, FDA etc.
Hi obourne, is the DWG made from Inventor or AutoCAD?
Comments
by Board Manager ihayesjr on ‎08-20-2012 03:23 PM
Status changed to: Comments Requested
by Distinguished Contributor obourne on ‎08-20-2012 03:29 PM
IV.
by Valued Contributor DannyVanDuijn ‎01-26-2013 07:53 AM - edited ‎01-26-2013 07:54 AM
A verificated Sign-off method would be very appreciated. When a file/item gets released by an user then the system must verify the user again by showing an extra sign off dialog where the user has to fill in its user credentials.
The workflow would be:
Login Vault > use credentials
Releasing a file / item > use credentials again.
Then the job processor generates the visualization file automatically (in pdf format).
Of course should this be a option which is controlled by the admin.
Danny van Duijn
by Contributor jeamy.baena on ‎06-06-2013 12:10 PM
Very important feature!
by Distinguished Contributor tahdesign on ‎11-18-2013 04:48 AM
This is what I was asking for in the following Discussion topic:
http://forums.autodesk.com/t5/Vault-General/Vault-Professional-2014-and-Digital-Signatures-for-relea...
This is something that I think everybody needs and should be built into the release work flow.
by Alain on ‎11-25-2013 08:19 AM
I agree, very important feature!
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea
Top Kudoed Authors
User Kudos Count
10
8
7
5
4
