Show only
Search instead for
Our VAR setup Vault Basic with Library.ipj and Projects.ipj which we are happy with. All files in Library are made and locked away (or I wish they were but that is another topic). But we are constantly adding items to the Library either as new or as copy design.
We have a similar need because we have template assemblies for tooling design on different pieces of manufacturing equipment. Many of the base machine's components are Library-type parts that will never (or rarely) change, but the final assemblies always contain some customized interchangeable parts like die sets, punches, form tools, grippers, cams, linear slides, levers, etc. that are essentially similar but never exactly alike. A convenient solution is to have complete assemblies of various machines+tooling, with the interchangeable components in place, ready to customize, and use Copy Design on that for each job.
My workaround has always been to keep these template assemblies in regular (non-library) folders, but that can cause frustrating problems with "library" components getting checked out unnecessarily or having lifecycle changes applied when they really shouldn't be.
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
