Circular Reference Warning
Have Vault warn users that a circular reference exists when checking in documents, at the very least.
Currently, I can check-in documents with a circular reference.  No warning appears, and the 'Uses' tab displays incorrectly the relationships.
5 Comments
This is in regards to AutoCAD, as Inventor doesn't allow this.
Maybe have Vault recognize the 'overlay' xref option with AutoCAD.
Josh_Hunt
I believe this has been improved but not solved with Vault 2016 because you are warned when an xref under an Overlay is missing. However https://forums.autodesk.com/t5/vault-ideas/where-is-the-unresolved-xref/idi-p/7106631
YounesYammouri
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
