Check admin rights when access administration
Can you add a message when accessing Tools/administration/Vault settings or Global settings.
The content of the message:
Information: You don't have administrator right, some options are not accessible.
Thanks in advance.
4 Comments
ihayesjr
Status changed to: Accepted
Cadmanto
I don't understand why a message is necessary to state the obvious.  If you don't have admin rights and you go in there under this login you wont be able to access these options.  Maybe the greater idea needs to be if you don't have admin rights, these options should be greyed out.
xavier_dumont2
Yes it's an another idea. My main problem: I want to modify an admin setting by example a lifecycle. You prepare all changes and when click OK, Vault just said "You don't have right access".... Grrrr.... 😉
ihayesjr
Vault now indicates that you are logged in as an Administrator using the status bar.
