It would be great if we could configure the software to Remove the 'submit and force approval' button and the 'fast track approval' button. Currently looks the same as the 'submit' button and this will get accidently pressed. I know you are going to say ‘your engineers shouldn’t have permission to force approval’. That’s right, we could set it up so this is the case. Unfortunately, we have had to make all our Engineers Change Order Administrators so they can edit the Change Routing List (Checker etc). Something Autodesk could rectify is to make the Change Order roles more configurable.
