0 Kudos
Autoloader with multiple instants of Inventor to generate visualizations
Status: Solution Provided
by Valued Contributor ACEDeSmedt on ‎08-31-2012 05:09 AM
I am using the autoloader to import our library in to vault with the creation of all the visualizations.
(The autoloader will open each file on the background and create an dwg file of it)
This is taken a lot of time and the process is running on a machine with 8 cores and is curently only using just 1 core for the processing.
This is a feature in Vault Workgroup and Professional.
Comments
by Board Manager ihayesjr on ‎09-26-2012 01:40 PM
Status changed to: Comments Requested
Hi, you can use the Job Processor to generate your DWF files while Autoloader is checking them into the Vault.
by Valued Contributor ACEDeSmedt ‎09-27-2012 01:31 AM - edited ‎09-27-2012 01:32 AM
correct me if I'm wrong, but i belief the Job Processor is not included in Vault Basic :smileywink:
regards,
Klaas De Smedt
by Board Manager ihayesjr on ‎01-28-2014 10:31 AM
by Board Manager ihayesjr on ‎01-28-2014 10:32 AM
Status changed to: Solution Provided
You are not logged in.
IdeaStation Guidelines
Review guidelines and best practices
before posting a new idea
Top Kudoed Authors
User Kudos Count
10
8
7
6
6
