I am using the autoloader to import our library in to vault with the creation of all the visualizations.
(The autoloader will open each file on the background and create an dwg file of it)
This is taken a lot of time and the process is running on a machine with 8 cores and is curently only using just 1 core for the processing.
Solved by ihayesjr. Go to Solution.
@ihayesjrwrote:
Hi, you can use the Job Processor to generate your DWF files while Autoloader is checking them into the Vault.
correct me if I'm wrong, but i belief the Job Processor is not included in Vault Basic 😉
regards,
Klaas De Smedt
