Autoloader be able to choose custom folders and dont add a ipj file to vault
when using autoloader you should be able to choose other folders other than the default. Also it adds a ipj file to vault which is not needed.
8 Comments
smilinger
Actually you can solve this by some configuration. After your first use of Autoloader, there will be a file named BUU.xml in your root folder, it is hidden, so just turn on "Show hidden files" in your vault option, then you can modify this xml file to set your folder configuration for Autoloader:
http://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
However, the solution is somehow cumbersome, it requires you set a library folder and it requires your workspace folder name same as your ipj file name.
Ben-Cornelius
Hi yes I am aware of this work around but I think it is ridiculous it seems only common sense that you could pick which folders you want
gabriele.bonacini
I'm perfectly in accord with bendesign
ihayesjr
The ipj is needed for other Vault functions after the files are added to Vault. If you already have an ipj in Vault, wouldn't you use it to load the other files using the Autoloader?
Ben-Cornelius
No because you are using the ipj file from the project that you want to upload
philip.s
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
