Description
Navisworks if great for comparing a historical and current model. It is not possible to load historical revisions from models to compare them to each other. On this moment you need to models with different names/file type to compare them.
Impact
Not having this feature has a significant impact on the process for comparing models during design phase, particularly one which has a somewhat complex or large modeling projects.
Due to this product limitation, it might actually put users off from using Vault in combination with Navisworks.
Severity
Medium-High
Solution
Streamline the UI functionality between all Vault add-ins. The best example is AutoCAD with the ability to use shortcuts, saved searches from the dialog. And make it this way possible to use Revisions of a file to be loaded. By solving this the users know what to expect when opening files from Vault.
