Always reload the local file in inventor when using the feature "Undo CheckOut"
For the moment, the "Undo Checkout" feature is working this way in Inventor:
- If the file is Checked-out in Inventor, modified and saved, then is the user is using the "undo Check-Out" option, the last version of the file in the Vault is correctly reloaded in Inventor
- If the file is Checked-out in Inventor, modified, but the user is using the "Undo Check-Out" option without saving the modifications, then nothing happens In Inventor. The last version of the file in Vault is not reloaded in Inventor.
It would be nice if the last version of the file were reloaded weather the unwanted modifications were previously saved in Inventor, or not.
4 Comments
ihayesjr
philip.s
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
