Allow Editing of UDP in Web Client and Thin Client
UDP (User Defined Properties) are great features.
If they are mapped to a file property it is not an issue here.
But if they are free-form, users need to be able to edit and add within the Thin Cient or Web Client.
UDPs should be completely editable online, if the users have access to add/edit files.
9 Comments
ihayesjr
gluckett
Able to edit UDP (User Defined Properties) in Thin Client.
Able to edit Category in Thin Client.
gluckett
Within the Thin Client, it would be nice for users to edit the UDP (User Defined Property) on line.<br>
Tags (1)
john.laidler
Not sure about this, as the Thin Client is only intended for 'read-only' access.
If you wanted 'edit' rights, then that would require a license.
gluckett
Yes but with office license you can check out...
ihayesjr
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
