good day, I have copy a design in the vault to test the file, but want to delete the copy now,
it doesnt allow me, to, how do I break the link between the file so I can delete the test.
Im the administrator
Jaco
You trying to delete one of several files from vault? It says something like "xxx.abc cannot be deleted because of Vault restriction".
Click the Details button, then check the ignore restrictions box.
Just be careful with this, cause when its gone...... its gone (unless you have a copy on your workspace).
Example of the error,... is this similar to what you are seeing? What does your error say? Can you post a shot of it?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
