Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
vault 2013 web client problem
3 REPLIES 3
SofiaGrave4819
273 Views, 3 Replies
Hello to all
I am running Vault 2013 collaborarion, and we have the web viewer for production where they are only allowed to see the release drawings.
we have some folder where the web viewer has permissions to read so they are able to visualize the files, but when doing a search for a file, the viewer also showns files that are in folders that the viewer have no permission.
could someone help me with this?
one more thing, why when i make a search i can see more then the file i am searching, there is a way to make a exact match search?
thanks for all teh help
Sofia
3 REPLIES 3
Dan_Malott
in reply to: SofiaGrave4819
The way I got around this issue was to set security level in the lifeccle defintions and had the files that were not to be seen by others were in a different catagory.
chearhuat
Alternatively, you may include the file extension in your search, e.g. '4046-6.idw'.
The search logic is based on partial string match, hence it is invariably that it will return all the files containing the search term.
Meanwhile, Vault security model differentiates folder and file viewing rights. You might have to apply the security rights up to individual file level.
Suggestion from dan.mallot would be a good implemention.
Hope it helps.
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
SofiaGrave4819
in reply to: chearhuat
Thank you for the answer, still i think it's a lot of work for a simple task like exact match naming. we have folder with web client permition and folders denied, I just don't understand why the search shows the denied folders.
But I accept the answer, even without solving my problem.
thanks for the effort.
Sophia
