I was hoping If someone could help me out with a serious issue i am having. Basically we upgraded from vault manufacturing 2010 to vault professional 2012.
The way we had set up our project structure was that we use to share "dwf" files between main project and the streamline folder( which was setup in vault) then use "get entire folder" function to to get the latest version of the shared files into the streamline folder, whcih then used to get synchornised with streamline/Buzzsaw online account or cloud space.
Problem now is that both the "share" and "get entire folder functions" have been removed from vault 2012 for unknown reasons. I was hoping if someone could help me with a work around this, any help would be greatly appreciated.
Hi there - I can't comment on the "Get Entire Folder" - However I have some info on the other issues and maybe a new setup that's improved.
With 2012 we now have a new publish tool from Vault to Streamline that uses the Job Server to sync a folder from Vault to a Folder in Streamline. Check out this blog.
This is SO much improve vs. before. You can even go crazy and set up rules on lifecycle state changes that will automatically publish files for you
For the Share command we've replaced this with new Links. There are a bunch of benefits to this but should accomplish a similar task.
One more to read - this is Part 2 of the Streamline blog showing you how to automatically set up the publish
http://autodeskmfg.typepad.com/blog/2011/05/sharing-managed-data-part-2.html
handy that!
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
That was useful, but the issue still remains as we do share files within different folders in the project. but in 2012 that seems to be have replaced by link which is shortcut and not the actual file, well we don't work like that. lets just say i have my dwg and dwf files in my main working folder "A" and I want to share the dwf files ONLY with a supplier. I have a supplier folder setup in vault, normally i would share the file with the supplier folder and then use streamline to upload it.
BUT NOW IN vault prodessional 2012
I cant do that I can only share or create a shortcut or soo called link the orginal file. This is where the problem is I dont want to just create a shortcut I want an actual physically shared file so that even if i delete the orginal file from main working folder I should still have shared version of the file in suppliers folder.
any suggestions????
My understanding is the Link behaves like a normal file, have you tried your workflow using the links? does it copy a shortcut to streamline or does it place a copy of the linked file into streamline?
Scott Moyse
