The following bullet is found in the readme:
"A new property has been added to the files in the vault called
Visualization Compliance. This property indicates if a visualization file
has been updated after the last change to the CAD file. This property has
several states that may be set; None, Compliant, Non-compliant, Legacy, and
User Verified. Because the Visualization Compliance property did not exist
in previous releases, all files within a migrated database will be given a
default value of Legacy. Upon selection of the view tab, a warning will
populate stating that the associated visualization file may be out of date.
Please see the help file for further details."
Hope this helps.
Craig
"vmaracle" wrote in message news:5956955@discussion.autodesk.com...
Thanks for the reply. The error message we are getting is,
Warning: The visualization file displayed is marked as non-compliant, and
may inaccurately reflect the data file!
I will look in the publishing options as suggested, so far it looks like
just the acad files are 11x17 but the error message shows up on all released
drawings
