When you are in an assembly in Inventor and select the Replace command, the
Inventor dialog box initially comes up. There are two buttons in the lower
left corner, and these allow you to toggle over to the Open/Place from Vault
dialog box. You can browse the Vault, use a pre-defined shortcut, saved
search, or run a basic/advanced search for files. As for placing multiple
files, I will forward this request on to Product Design.
Brian Schanen
Customer Success Engineer, Data Management
"designengineer" wrote in message news:5957929@discussion.autodesk.com...
> When using IV.
> Why don't we get to replace files from the vault?
> Why can't I place multiple files from the vault?
> This makes for a painfull & sloppy workflow!
> Will these simple things be in the 2010 release?
