Thanks Sue,
That's very helpful. Here's another question: On my machine I have the
Vault working directory set to a location on my hard drive, but the
files seem to be going to the server instead. Of course the vaulted
files are stored on the server, but there is also a non-vault directory
structure that appears to be used rather than the local "working directory".
Any ideas on that?
Alan
Squeezer wrote:
> "Place" is an Inventor assembly command to add a component you already have in your local workspace to the iam.
> With "place", you get an open file dialog box that lists the folders & files on your local workspace.
> "Place from vault" is actually doing the same thing but running a secondary vault command of "get latest" transparently & then returning you back into the still runing Inventor "place" command.
> Place from Vault will start the same "open" dialog box, but the folders & files listed are the vault folders rather than the locals. (it is actually looking into the vault database.) When you "place from vault", choose a file & OK, Vault runs a "get latest" on the file & downloads it to the local workspace, then immediatly returns you to the Place in progress.
> Place from vault is used when you are adding a component to an assy that you don't already have downloaded to your workspace.
> If you add parts to a checked out iam & save it, when you switch from model browser to vault browser you'll see "?" if the files are not in the vault (new files added by "place"). You'll be required to 1st add the new files before you can check the iam back in.
> With existing vaulted components, (added by either place or place from vault) when you save the iam, and check it into the vault, any component that was added to the iam will be checked in with it. Actually only components that were checked out and changed, get checked in. Any component that was checked out & not changed has an undo checkout performed on it.
> It will all happen automatically, regardless of where the copy of the component started out from.
> Hope this helps.
> Sue
