Just started getting this error:
multiple instances of autodesk data management server console 2013 are not allowed
This can happen usually if you use terminal services/remote desktop to access your server remotely.
Look at Task Manager and look for the Connectivity.ADMSConsole.exe process and see if it is already running. Usually the case is that it is running in another session.
-Hywell
Yes I do use RDT often, I was thinkng the backup wasnt finishing or taking too long. I did stop the Connectivity ADMSConsole as I did see it running after the backup had fininshed.
