Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
how Change vault explorer database default
3 REPLIES 3
vallourec
298 Views, 3 Replies
Hy,
I would like to know if it's possible to change the default vault database in Vault explorer on the login page ?
We use the windows connection, but the name of the vault database is not vault, and users have to manually select the vault who's name is DV and the security of our society delete all information as we close IE...
Do you know where i can put the vault name 'DV' instead of "VAULT" ? in the web site config probably ?
Thanks for your reply.
Bellemere JP
3 REPLIES 3
ihayesjr
in reply to: vallourec
Look in the users profile for a file called LoginHistory.xml.  Edit it and remove the "Vault" from the list.
In Windows 7, it can be found here: C:\Users\username\AppData\Roaming\Autodesk\VaultCommon
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
vallourec
in reply to: ihayesjr
Hy and thanks for your reply
I don't find this file on my computer..
And i want to to that on the Vault server for all the vault explorer client.
i try to find something on the login.aspx page of the vault website but i don't succeed...
Another idea ?
Bellemere JP
ihayesjr
This isn't something you can set on the server.
The path I gave is a hidden path so you will have to unhide the directory or just type it in and Windows Explorer will allow you to go there.
Irvin Hayes Jr
Sr. Product Manager
Autodesk, Inc.
