Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
error: IIS is not running as the default web server
12 REPLIES 12
Message 1 of 13
Daniel514bama
3632 Views, 12 Replies
I am trying to install the latest vault hotfix "Error Getting Relative Resource Path during checkin of Inventor files" since I am having the described problem. I followed the instructions for installing, but got the following error during installation "IIS is not running as the default web server." Then the next dialog box reads, “A problem prevented the hotfix from being installed. Contact your system administrator. Error Code 1603.” Any ideas?
Daniel
Server OS = Win 2000 SP4
Vault 4 SP2
Vault Server SP2
12 REPLIES 12
Message 2 of 13
in reply to: Daniel514bama
Is IIS installed on your machine or are you using AutodeskWebService?
Please post the log files created by the installer in your temp directory
(%TEMP%)
Ajay Choudhary
Software Engineer
Autodesk Inc.
wrote in message news:5088155@discussion.autodesk.com...
server." Then the next dialog box reads, "A problem prevented the hotfix
from being installed. Contact your system administrator. Error Code 1603."
Any ideas?
Daniel
Vault 4 SP2
Vault Server SP2
Message 3 of 13
Daniel,
Make sure you stop the web service before installing the hotfix (just double
checking in case you didn't do that).
Bob
Any ideas?
Daniel
Vault 4 SP2
Vault Server SP2
Message 4 of 13
I believe we are running AutodeskWebService. I am posting contents of what is hopefully the correct log file. I have also included a screen shot of installed programs.
Daniel
Message 5 of 13
Bob, I did stop the web service. Thanks.
Daniel
Message 6 of 13
Using the Autodesk Web Service (AWS) means you would not be connecting to
the Vault server from any clients machines - only the server itself. Is that
the case? If so, just stop the Autodesk Web Service before installing the
hotfix. You can start Vault Manager, stop the web service, exit (not
restarting it), then apply the hotfix.
Let's see if that does the trick.
Bob
wrote in message news:5088234@discussion.autodesk.com...
installed programs.
Daniel
Message 7 of 13
Bob, I did as you suggested and stopped the web service and exited without re-starting, then re-tried the install. Still having the same error.
Daniel
Message 8 of 13
Sorry, we must be running IIS because we do connect from several client machines.
Daniel
Message 9 of 13
Please run the Diagnostic tool and post the output file.
Ajay Choudhary
Software Engineer
Autodesk Inc.
wrote in message news:5088274@discussion.autodesk.com...
Daniel
Message 10 of 13
Here's the log.
Message 11 of 13
Hi Ajay,
Just wondering if the diagnostic output helped give any clues as to what might be happening. Does it look like a serious problem?
Daniel
Message 12 of 13
Hi Daniel,
The diagnostic tools output looks fine. It shows that you have IIS 5.0
running and responding to requests.
I do not know much about the hot fix you are trying to install. So I waited
for someone else to pitch in.
Please contact the Autodesk Customer Support.
Ajay Choudhary
Software Engineer
Autodesk Inc.
wrote in message news:5089688@discussion.autodesk.com...
Hi Ajay,
Daniel
Message 13 of 13
llocatelli
Are you open SKYPE?
close this program
