Vault General
Distinguished Contributor
JimSteinmeyer
Message 1 of 3 (130 Views)
copys of same file in vault 2012/
130 Views, 2 Replies
12-13-2011 02:17 PM
Comming from both Pro and SW I thought that with Vault files would be checked and only one instance of an item would be allowed in the vault. For example if XYZ.ipt exists in one assembly in vault and I attempt to enter a totally unrelated part XYZ.ipt in the vault I would be notified of it and either would not be allowed to enter it or the new assembly would point to the existing version of XYZ.ipt. This was one of the main reasons I gave my superiors for purchasing Vault.
Now I open vault and search for XYZ.prt and find it located in 6 different places. How do I make sure every part/assembly only has one active model in the vault and that allassemblies or drawings pointing to part XYZ.ipt point to the same one?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
Employee
olearya
Message 2 of 3 (127 Views)
Re: copys of same file in vault 2012/
12-13-2011 02:40 PM in reply to: JimSteinmeyer
Hi JIm,
Under the administration tools > Vault settings you are able to "Enforce Unique File Names" - this ensures that no files can be added to Vault where the same name already exists.
Next to this option is a tool which permits you to find duplicates, this will report all pre-existing duplicate file names and enable you to start the process of renaming/replacing/deleting and otherwise rationalizing the data.
Unfortunately this process will need to be done manually if you are uncertain of the validity of each file, as in, are the duplicates identical, is one newer than the other or are they simply named the same.
Hope this helps
Allan
Product Manager
JimSteinmeyer
Message 3 of 3 (113 Views)
12-14-2011 07:25 AM in reply to: olearya
Thank you. This is what I was looking for. We must have turned this off to load the existing files with the intention of going back to clean everything up once the assemblies are all entered.
Thank you
Jim
Jim
HP G71 notebook
Win 7 home premium
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
