You could change the working folder using Vault Explorer, select "Vault
Explorer ($)" first, and then Set Working Folder... from File menu. From the
dialog, select the path of a new root folder say C:\Projects. If you're
logged into Vault from ACAD while changing the working folder, re-login from
ACAD to "know" the new working folder path.
Chee-Kit
"Demitri123" wrote in message news:5959959@discussion.autodesk.com...
> I want to change the path where the check out file from vault will be set
> in. How can I do this? Currently it is on my local user account's my
> document folder. Please somebody help
