Vault General
New Member
lypatric
Message 1 of 17 (1,840 Views)
Accepted Solution
Windows Authentication component broke???
1840 Views, 16 Replies
08-31-2011 01:27 PM
Hi all,
About two months ago, We upgraded our vault manufacturing 2010 to Vault professional 2011/SP1 and SP2.
And windows Authenticaiton works just fine. Up until last week users can no longer logon to vault using vault server by name. it worked if we use the server's IP ADDRESS along windows Authentication option.
I dont think this is a DNS issue. Because we can use vault local account to logon to vault server regardless we are using vault server by name or by IP Address.
Please help.
Thank you in advance.
Product Support
herrerh
Message 2 of 17 (1,834 Views)
Re: Windows Authentication component broke???
08-31-2011 01:52 PM in reply to: lypatric
What error do you get when trying to login via Windows Authentication and the computer name?
Can you post the vlog from the server?
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
New Member
lypatric
Message 3 of 17 (1,802 Views)
09-01-2011 11:18 AM in reply to: herrerh
Attached are the vlogs. Also attached an error message when we logged on to vault server using server name. Successful with IP address.
Best regards,
Distinguished Contributor
jeff_jordan
Message 4 of 17 (1,725 Views)
11-11-2011 01:58 PM in reply to: lypatric
Did you find a solution for this?  I'm having the same issue.  Windows Authentication was working, but after Vault 2012 Pro Update 1 was applied, logins aren't working.
Autodesk Product Design Suite 2012 (Inventor 2012 Pro SP1, Vault 2012 Pro Update 1)
Windows 7, 64-bit
Intel Core i7
8GB
Nvidia Quadro FX 3800M
jeff_jordan
Message 5 of 17 (1,672 Views)
11-23-2011 10:24 AM in reply to: jeff_jordan
Still broken!  Extremely frustrating.  Our consultants and Autodesk say they've never seen this before.
Windows 7, 64-bit
Intel Core i7
8GB
Product Support
r.smith1
Message 6 of 17 (1,665 Views)
11-23-2011 12:53 PM in reply to: jeff_jordan
HI Jeff,
As per our discussion today regarding your support case, we had you remove IIS, reinstall IIS and added in Roles:
Security
set basics authentication IIS Client Certificate mapping
Management Tools
IIS management scripts
IIS 6 management compatibility
IIS6 scripting tools
WinAuth settings in IIS, enabled Windows Authentication, disabled asp.net Impersonation.
Made sure default apppool regular time interval is set to suggested numbers per WinAuth White Paper (17400).
Stopped IIS. [using command iiisreset /stop]
Deleted the folder:
C:\Windows\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\autodeskdm_services
Started IIS. [using command iiisreset /start]
Once all was added, WinAuth started functioning again.
Feel free to reply and add the screen shots taken fro others to review.
Please tag this as a solution to resolve this issue.
Ron Smith
Front Line Technical Support Specialist - Data Management
Autodesk, Inc.
http://help.autodesk.com/view/VAULT/2014/ENU/
http://crackingthevault.typepad.com/
http://underthehood-autodesk.typepad.com/
jeff_jordan
Message 7 of 17 (1,663 Views)
11-23-2011 01:20 PM in reply to: r.smith1
Ron, thanks for all of your help today.  I've taken screenshots of almost all of our configurations for future reference.  Too many to post here, but if someone runs into this issue, perhaps I can help.  Enjoy your weekend!
Windows 7, 64-bit
Intel Core i7
8GB
Product Support
r.smith1
Message 8 of 17 (1,659 Views)
11-23-2011 01:37 PM in reply to: jeff_jordan
Thanks Jeff, You as well.
Ron Smith
Autodesk, Inc.
idubail
Message 9 of 17 (1,545 Views)
Re : Windows Authentication component broke???
03-20-2012 12:18 AM in reply to: lypatric
Hi Jeff,
I have exactly the same issue at the moment, can you please (!) explain me how you've resolved it ?
It occurs after installation of Upgrade 1 on Vault Pro 2012.
Thanks in advance !!!
idubail
Message 10 of 17 (1,535 Views)
03-20-2012 01:25 AM in reply to: idubail
Issue resolved... after reinstalling IIS, I used IP Adress instead of Server Name and it works !
Hope it helps, and hope that Autodesk is working on a solution !
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
