Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Wierd folder renaming problem.
6 REPLIES 6
439 Views, 6 Replies
I am just trying to rename a folder in vault 2010 which contains a number of files that are linked together as well as linked to files outside of the folder.  I have made sure my workspace is empty and all files are checked in, so nothing checked out and nothing sitting on my harddrive. I then right click, rename, enter the new name and press return. Processing starts and returns an error attached and then low and behold I have one of the files checked out. Always the same file. I tried this on other guys computer and it does the exact same thing. Tried deleting all the files in the temp folder, no change. Any ideas?
Ozitag
6 REPLIES 6
mpatchus
Any ideas on this issue? We also receive this error when renaming files, but only occaisionally. I personally think it is a number of character limitation due to the rediculously long temporary folder that Vault uses. Is there any way around this??
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
mpatchus
in reply to: mpatchus
After some investigating I think the problem lies with the Max file size limitation being set to 50mb in Vault.
Here's a link to how to change the default Max size.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4445223&linkID=9261340
Hope this helps... Mike
Inventor 2025 Beta
Never did get a solution to it. I can't even remember exactly which files it was now.
I also don't think it is the size issue you pointed out as we have always been able to add larger files. (I just checked and there are quite a few files that are greater than 50Mb, some over 100Mb.)
Something that it could be, although this is a long shot from left field, is a problem with a texture. If the part is an iPart, INV copies all the textures and colours etc into the file. If there is one that has an issue, then it creates unusual problems. Do a purge on the files and see if it changes it. But as I said, it is a suggestion from way outside.
Ozitag
mpatchus
Oz,
The issue doesn't seem to be with adding files larger than 50mb.  They seem to go into the Vault fine.
It looks like the issue occurs when you try and check them in and out during a rename that causes the error.
Our files went into the Vault fine, but once they were there, we couldn't rename them because of the size limitation.
Mike
Inventor 2025 Beta
Yep, I tried to rename a large file and it bombed out as first described. Looked in to doing the change you mentioned before and couldn't find those files. It's not a great issue for me as I don't rename large files very often, but it's good to know the reason for the error and that it is an error. Will send the problem to my reseller and they can forward it to Autodesk, unless Autodesk reads this and can log it as needing a change.
Thanks for the info,
Ozitag
Madhan_T
Thank you for reporting this and we appreciate for finding the cause as well. I will forward this.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
