I have a drawing that I just checked out of the vault. When I select this command
to fill out the data card so that info can populate my title block in the drawing I get this message.
Anyone know what it means and how to get around it or prevent it from happening?
Solved by Cadmanto. Go to Solution.
Ok, I should have seen this one coming.
I started to recreate this same drawing in a different drawing file and I was able to update the data card like I have so many times before. Then I crashed. Went back to my original drawing that was giving me the error and viola!!!
I didn't get the error message and I was able to update my data card.
Go figure!!! Should have known after seeing a strange new error message I was about to crash!!!
I have seen this error message in other applications, with one common thread: SQL. I don't know what it means, and I think the person who came up with the error message ought to be severely beaten. There was a thread I saw somewhere full of vague and non-sensical error message. Some were even worse than this one.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
