Has anyone seen this before? In 2012, I did a search in the web client in items and found the desired item. When I go to that item's attachments, I see two listings for the same IDW. Both links open the same file. When I look at this in the full client, I see the single link to that drawing. When I search files, there is only one. Is this a defect?
Mark
I saw it also,only once it happened to me.
In the Vault client you see only one drawing but the web shows two.
I closed it and reopened since thne it has not happened to me.
Dan
