I have autocad and inventor drawings in vault pro 2011 I can select the update view on an inventor part and the visualization file will be updated and works fine. when I select an autocad file (dwg) I get the error "Update View Restriction" visualization file cannot be created for "file name.dwg" due to vaulting restrictions. when I expand the details it stats the File Type is not supported. 2010 used to work fine updating files, have any ideas?
I 've had problems with the Visualization files in Vault 2011 as well.
If you go to VAULT SETTINGS - VISUALIZATION (tab) - OPTIONS (button) - this will bring up the PUBLISH OPTIONS dialog box...
Change the pull down to AutoCad and AutoCad Common and check the settings...
Are the vault settings you mention in autocad or vault , I have looked in both but cant find a menu
