I have my visualization settings in Vault 2015 set up the same way they were in 2013. For my Autocad products, I have them set to create visualizations from Layout tab, Monochrome, 11 x 17. In 2013 this was perfect. From inside Autocad when I check in, I check Create Visualization on Check In, using Default Settings. What I am getting as a result is a full color dwf of the model tab. But when I use the Update tool in Vault Client, it repairs itself to the default settings, as it should have from the start. No Job Processor is being used. Support Case opened, #09691969 Here are some images.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
One more attachment, after update....
EDIT:
This only appears to be happening in Autocad Electrical.
Chris Benner
Hi Chris,
I grabbed your case and will work with you in the support request.
Thank you, Ron.
Once we get the resolution I will post it here for future reference. I appreciate your help.
Chris Benner
4 years later - having a similar issue - any idea what the resolution was, if any?
Both Inventor and ACAD Electrical are incorrect here, and even doing a manual update, it's still wrong.
Inventor/Vault/ACAD 2018
